Axle swap
Discussion in 'The Garage' started by burban1500, Feb 6, 2006.
  1. burban1500
    burban1500 Registered Member
    Nov 27, 2003
    46
    Lavallette, NJ
    IM ABOUT TO SWAP FROM A 10 TO 14 BOLT AXLE IN MY 89 SUB AND WAS WONDERING WHAT TRUCK AND YEAR IMPARTICULAR THAT I SHOULD LOOK FOR. I AM AWARE THAT I SHOULD FIND AN AXLE OUT OF A 3/4 TON INSTEAD OF 1 TON DUE TO SPRING/SHOCK RELOCATIONS. ALSO IS THEIR A WAY OF TELLING WHAT GEARS THESE THINGS HAVE BY PULLING THE COVERS?
    -Thanks in advance for the help
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    any year will be fine. count teeth with cover off, or twist yoke and count number of times u turn it for 1 full rotation.
  3. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    it'd probably be best to pick up a set of 3/4 ton axles, not just the rear. plus the front will have bigger calipers than your stock 1/2 ton. i would feel more comfortable with 3/4 gear out of a post '77 (i think that was the break) when the front axle tube diameter was 3" instead of 2.75. there's probably no real difference, i just like the idea of beefier stuff under my rig and 3 is bigger than 2.75. :) just to clarify what muddybuddy said, you count the teeth on the ring gear and divide that number by the number of teeth on the pinion. also, i believe that to prevent any problems with spring/shock location, the 3/4 ton gear needs to come out of a truck or burb, not a van.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    1/2ton and 3/4ton calipers are the same
  5. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    really? i had always been told the 3/4 were beefier. well, i stand corrected.
  6. brotha b
    brotha b Registered Member
    Nov 4, 2005
    31
    vernal, Ut
    that is the truth
  7. gmcman7202
    gmcman7202 1/2 ton status
    Sep 19, 2005
    181
    The land of FIBS
    if the caliapers the same, but are the distance from the center of the axle differnet, such as larger rotors? if so the statics will show that the same caliber will place a greater stoping force upon the larger roter, since being further away from the center.... thus better braking with the same equipment...
  8. burbanbeast
    burbanbeast 1/2 ton status
    Jan 24, 2006
    103
    Collierville
    i have a question that relates to what yall said earlier bout the shock relocation and all would a 14b/d60 of a cucv fit on my burban (same as his 89gmc) or would it suck to do
