Axle Swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JoseK5, Dec 14, 2001.
  1. JoseK5
    JoseK5 Registered Member
    Dec 12, 2001
    62
    Lebanon
    Hi,
    I have found two Dana 60 off a Dodge truck. The front is a wide 35 spline heavy mother, and the rear is a regular Dana 60. I had to weld new spring and shock mounts to both of them. the rear is not so tough to install, but i got stuck with the steering part on the front one. Is there a known solution for that? or I just have to start some cutting and fitting? I will really appreciate all kind of help. Thanks
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    What is the problem you are having EXACTLY with connecting the steering? Fill out your profiles so the folks here can help you better...
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s - 36" TSLs
  3. JoseK5
    Dec 12, 2001
    62
    Lebanon
    Hi,
    Since the axle I'm installing is not a chevy, some mods need to be done. I would like to know if should fabricate stuff to make it work, or if there is an aftermarket kit for that?
