Axle Trusses for GM10bolt. I know, I know, jus humor me.
Discussion in 'The Garage' started by badmix, Feb 22, 2007.
  1. badmix
    badmix 1/2 ton status
    Nov 7, 2004
    4,205
    60
    West Virginia
    I plan to stick with my GM 10bolt for now. I know I know its not the best, but it works for me and I can keep my truck fairly stock. Anyways. Does anyone know where to find and/or buy rear axle truss and would I benefit from it? Thanks.
  2. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    I plan to stick with the 10 bolts for now as well. I am only running 33's and don't play in the rocks so odds of snapping one are lower - but still there.
    Thing is, I already have 2 full sets and have had several others offered for nothing. So I figure the cost of the truss would be WAY higher then the replacement 10 bolt:D
  3. dyeager535
    26,976
    Most common 10 bolt failures are the carrier (gov-lock) and from what I've seen here, the ends of the axleshaft, but that is REALLY uncommon.
    I know the one failure has nothing to do with flexing axle tubes, and I suspect the other doesn't either. If you aren't doing anything serious enough to require a bigger axle, you probably don't need trusses. Plenty of people use 10 bolts both on and off road who don't use trusses, so I don't expect they help enough to be worth it.
  4. BigEasy
    BigEasy 1/2 ton status
    Dec 18, 2006
    418
    U-jeen, Oragun
    Actually, I have a set of trusses too.:haha:
  5. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    If you'd like to get rid of those trusses, let me know. Are they for front and rear, just rear, what?
  6. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    Why does that figure?:crazy:
    So did you actually USE them before you went to 3/4 ton gear?
    Oh, you asked about fishing in your PM...
    Does that answer the questions?:D
  7. BigEasy
    Dec 18, 2006
    418
    U-jeen, Oragun
    SWEET! :saweet: You know I'm gonna be begging you to go fishing now, right? :D
    The trusses came off a truck I had previously. I've got both the front & the rear but somehow I misplaced the u-bolts for one of them, I can't remember which one right now. All I know is that shipping those things would probably cost a bundle.
  8. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
