Axle tubes.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Moose, Aug 12, 2000.
  1. Moose
    Moose 1/2 ton status
    1,062
    Glendale, Arizona
    Anyone ever had this problem? I just got had a set of 4:11 and locker in the rear and the day after that I got on it a little and heard 2 pops. When I got to work I looked underneth the truck and the 3 welds in the passenger side tube had came out. Has anyone ever rewelded the a tube in the housing/
  2. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    wow, never heard of the tubes popping out just driving around. i have previously broken many, but that was becuase i kept jumping the truck......i'm a bird....i'm a plane......i'm superk5!!!!
    no seriously tho', i once wanted to weld my tubes in the housing but there were people who had many different feelings about it.
    i would like to know the pros and cons of doing this.
    Knife.
    knife.coloradok5.com
  3. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    Are you sure the welds came out? If you had a Detroit installed, it can pop so loud after you make a turn, it'll sound like an axle shaft or R/P broke but everything is alright. If you don't have fluid leaking out the diff.,wait a few days and check again-if the welds did break, you'll have a leak.
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I had something similar happen in an elcamino I had. the spot welds didn't hold and when I hammered on it the torque would cause the tube to turn in the main housing. they can be welded BUT by a very good welder and the correct welding rod. cast iron to steel is difficult. alot of heat and special rod for cast iron. If you are not carefull you can weaken the tube when welded. DO NOT weld fully around the tube. stitch weld it.
    your right. I don't understand the jeep thing!
  5. Moose
    1,062
    Glendale, Arizona
    I rewelded them today. 3 of the spot welds popped out cleam holes all the way to the tubes. Talked to a guy at the run today and he gave me advice on how to weld. Weld it in the center of the hole and build it all the way out.
