Axle upgrade question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Muddytazz, Jul 10, 2002.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I currently am running stock D44sf front and 12 bolt sf rear with stock gears (3.08's now, want at least 4.10's) under a 1/2t suburban (full time 4wd w/NP203). What I wanna do is put a complete set of 3/4t axles under it. What should i start looking for, and will I have to convert my t-case, or did 3/4t's come with full time 4wd with np203's?
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    well first your front end is a FF, all front axles are, look at the end/hub area of your rear end, see there is no big hub sticking out. now look at the front, there's a hub there. the hub carries all the weight on a FF and on a SF the axle shaft carries it all.
    to go 3/4 ton you should look for at least an 8-lug 14bolt SF and an 8-lug front D44 or 10 bolt. the D44 and 10B aren't much different at all. but try to get a 14 bolt FF rear.
    don't know about the case, my 3/4 sub has an NP241 in it which is part time.
  3. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    Hey, im gettin ready to put my axles in. i have a '79 with the 10b and 12b. i got my 3/4 axles(d44ff,14bff) from a guy on this site that pulled them from a 78 3/4 p/u. i got those, np203, th350, and alot of misc. parts for $150. the main thing u will hafta do is get new u-bolts, and a conversion u joint which is like $27 at napa. ill b putting mine on shortly. there are also a few other little things that u will need. just figure out as u go along.
    NITRO
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Why in the hell would chevy put a full float in the front a and a semi float in the rear? Seems dumb if you ask me.
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> All steering axles are full floaters, it's the nature of the beast. There is no way to make an axle that steers that is not a full floater. </font color>
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Thats understandable, just didn't know why they would do one of each.
  7. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Probably because a semifloater is a lot cheaper to make, and a 1/2 ton doesn't really need the strength of a full floater.. </font color>
  8. muddysub
    Jun 23, 2001
    10,451
    489
    semi floaters are lighter too.
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I'm going to change to 3/4t axles, should i go with the 12bolt ff or go with the 14ff
  10. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    hell yes they are lgither. i am tired of moving my 14 bolt around. just need another 500 bucks and it will go under the truck... anybody want to buy a top off a 74?
    grant
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    Depends on if you already have large tires and rims and want to shell out more cash to change to 8 lug rims if you do the 14FF swap. /forums/images/icons/wink.gif
  12. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> There was never a factory 12 bolt FF made, and it will cost like $800 to convert a SF to a FF, so I'd go with the 14 bolt. You should be able to pick up a 14 bolt in great shape for $250 tops, add a Detroit for $330 and you'll have a great axle. </font color>
  13. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    My next question then with my 1/2 ton with D44/12bolt with 3.07's...I want to upgrade to 3/4 ton with 4.10's and I want to leave it full time 4wd...I know i can get a 12b 3/4ton with 4.10's, but does the D44 4.10's come in 3/4ton?
  14. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    read my last post, except replace 12b with 14bolt..I want a 14 not a 12, also, just thought of something, since I have a 12bsf on now, and I'll be going to a 14b ff, how much of the driveline will i have to change (oh t-case is np203).
