Axle Upgrade Question
Discussion in '1936-Present Suburban' started by sanddragon2004, May 14, 2003.
  1. sanddragon2004
    sanddragon2004 Registered Member
    Feb 19, 2003
    80
    San Jose
    going from 10 bolts front and rear to dana 44f/corp 14 rear 13" brakes.
    does this require replacing the booster, and master? or direct bolt in on 89 1/2 ton sub?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Nope, just swap and go. /forums/images/graemlins/thumb.gif
  3. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    My 91 took U-Bolts & the fancy U-Joint (Nappa 447).
    Mine was different as far as the Parking brake cable goes, but aren't those optional equipment?? /forums/images/graemlins/rotfl.gif
    May need a speedo correction depending on what you're doing with ratio/tire-size.
    Very easy swap with air-tools!
