axle width measurements
Discussion in 'OffRoad Design' started by **DONOTDELETE**, Jan 8, 2001.
    I was wondering what a stock axle's width is:
    14 bolt/10.5"
    D44 front K5/15
    D60 front K25/35 non dually rims
    thanx if you have em!!
  1. I have a dana 60 front and 14 bolt rear on my garage floor and they measure; 69" flange to flange on the dana 60; 67" flange to flange on the 14 bolt rear. I dont know the dana 44 as its in my other shed. Would have to run over and measure later.
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We've found the 6 lug fronts are 67 1/2" and the rears are about 64 1/2" I think?
    SW-ORD
  3. CK5
    May 19, 1999
    21,623
    701
    CO
    A rear 10 bolt is 3" narrower than the front 10 bolt/Dana 44 and a 14ff is 2" narrower than the front, but a 14ff (maybe a 12) from a GM van is somewhere around 1" wider than the front 10/44.
    Steve
    1990 K5 with stuff
  4. It would waste the effort to put in a 6 lug(semi-float) 14 bolt in. The point is to eliminate breakage. From what i've seen the semi-float has a 9.5 or 9.75" ring gear and smaller axle shafts. I still have to narrow both by 6".
  5. RUSS84K5
    RUSS84K5 1/2 ton status
    Jan 9, 2001
    172
    NEW HAMSHIRE
    I had a semi floater in my blazer until the pinion bearing let go.
    Later when I rebuilt it for my stock truck I had a chance to look at everything. The ring gear is 9.5 the shafts have 30 splines (same as the 14 FF). and i'm pretty sure the shaft dia. is the same. The one I have has 8 lugs. I think the light duty 2500s that came out in 87 would have the six lugs, normal 2500s had 8 lugs and 3500 14 FF 8 lug.
  6. RGF
    RGF 1/2 ton status
    Jan 5, 2001
    281
    Maine
    If anybody is interested the width of a van FF 14bolt from a SRW C30 is 70" flange to flange, and you will be moving the spring pads( 50 1/2" ) You can probably pick one up for less than the price of wheel spacers and have piece of mind when hooking up your 2000lb trailer with a 6000lb wheeler on it! RGF
