axle widths
Discussion in 'The Garage' started by Pow06er, Jan 15, 2006.
  1. Pow06er
    Pow06er 1/2 ton status
    Apr 9, 2005
    188
    ne, ohio
    Are 10bolts in k5's narrower than 10bolts in 88-98?
    I have a 14sf from a Older 2wd Suburban the style before 92 and I want to make it work
  2. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    can you clarify your question?
  3. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    is the 10bolt rear end WMS in the OBS 88-98 k series trucks wider than the WMS of the 73-91?
    seems like the 10bolt in my '88 is narrower than the 10 bolt in my dad's '96
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    My friend took the 10 bolt rear out of his '96 Z71 and replaced it with a 14 bolt FF from a '79 k20, the two were within a half inch of being the same width.
    The 88-98 trucks have the spring mounting pads spaced out more than the 73-87 trucks, but that is an easy fix. The shock mounts are spaced differently as well.
  5. dyeager535
    26,980
    I thought the difference was 3" new vs. old?
    My 14SF out of a 90's truck definitely was wider by 3". (vs. the '86 10 bolt in it). Spring perches obviously in the wrong spot.
  6. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    Well I got a 14sf from a 2wd and I wanted to use it on my '88 k5 and I dont want it to be too narrow
    The 14sf was too narrow for the 96 OBS I had
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    They should be pretty close. I think rear 10bolts are around 65" and if that 14SF came out of an older truck, then it should be similar. New body styles went wider to about 67"...
    The 3/4 ton and 1 ton stuff is wider at 67.5" rear, 69.5"(SRW)front....
  8. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    well I believe the 14sf from the 2wd is 64" WMS to WMS
    If the 14sf is wider i dont care but if its only an inch narrow then I'll still use it
  9. divorced
    Jul 20, 2004
    5,115
    What year/model truck is the 14sf from?
  10. dyeager535
    26,980
    My 14SF is 68" WMS-WMS.
    Supposedly '97 tahoe.
  11. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    forget this Ive decided it's pointless and Ill wait and save for a 14ff and 8 lug
