Axle Woes *DELETED* *DELETED*
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 1bigchev, Feb 10, 2003.
  1. 1bigchev
    1bigchev Registered Member
    Jan 27, 2003
    8
    utah
    Post deleted by 1bigchev
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Re: Axle Woes
    You can go up to 35" tire without too much wory.
    There are many weak areas on a D44/10Bolt.
    1) Small u-joints (and when they go they take out other stuff with them)
    2) Small axle shafts
    3) Small bolts that hold the spindle on
    4) Balljoints
    5) Stock carrier
    6) R&P
    Axle shafts, carriers, and R&P can be broken and you could still get home in 2wd...
    IMO it is the spindle and balljoints that make the D44 a problem with bigger tires.
