axle wrap cure???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1990K5, Jan 21, 2001.
  1. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    does anybody have or know of any good ways to cure axle wrap w/out limiting articulation? don't care if its homemade or store bought. was thinking of a bar that could twist and be attached to the houseing and the frame w/bushings to keep the pinion in one place. any ideas???
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if you find anything out please let me know as i would like to do this also
    s.smith 77blazer lookin 4 mud
  3. Grim-Reaper
    7,385
    Atlanta
    Get rid of the blocks if you got them. They put extra leverage on the springs. If you still have a problem once you get rid of the blocks then a torq arm with a shackle at the end would be the best way to go without limiting flex.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  4. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Most axle wrap is due to the blocks in the rear as Grim-Reaper said. You can eather remove the blocks and use a spring lift or you can due a Shackle flip and keep the stock springs in the rear. There are companies that makes traction bars but they normally limit the arc of the springs.
    C'moe
    <font color=black>the blazer is "Back in Black"
