Axle wrap help, what do you run?
Discussion in 'The Garage' started by icer97, Jun 16, 2005.
  1. icer97
    icer97 1/2 ton status
    Jun 15, 2005
    116
    Missouri
    Just wondering what everyone has done to prevent nasty axle wrap. Ive seen several designed braces to help, what do you run? Are traction bars as good as they advertise to be? I see that Missouri offroad has out a axle wrap reducer.
  2. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    well, what kind of suspension do you have? blocks? springs? shackles? traction bars limit articulation...so if your into crawling dont go that route. if its a street truck then by all means get some...
  3. icer97
    Jun 15, 2005
    116
    Missouri
    I have a ff14 bolt, running 8 in suspension. I reclocked the perches and welded blocks. Stock springs and shackles. I wont do much crawling, mostly mud, but want to be able to flex if needed.
  4. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Using one of the traction bars that has a shackle at the frame end and heims or some type of flexible joint if you solid mount the frame end it will reduce traction remember all you are trying to control is the rotation of the axle not front to back
  5. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    294
    Truckee, CA
    IF by welded blocks, you mean blocks between teh axle and spring, ditch those.
    They exaggerate any axle wrap you migh have.
  6. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    as above listed. lift blocks = lots of axle wrap. and lift springs = less wrap but stiffer ride and some loss in flex.
  7. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
    I built my traction bar the way Blazinzuk is talking about. It takes care of the axle wrap and does not limit flex.
  8. icer97
    Jun 15, 2005
    116
    Missouri
    I dont have permission to access your pictures :(
  9. seschev3
    Jan 19, 2005
    308
    clayton, ca
    Remember that a picture is worth a 1000 words. So pay up and become a member. The pics on this site will blow your mind and make you think of creative ideas that will repay your membership over and over again.
  10. icer97
    Jun 15, 2005
    116
    Missouri
    Ah yes I see now. You were right, well worth the $25.00. :grin:
