Axle Wrap/Hop
Discussion in 'The Garage' started by stockk5, Feb 5, 2007.
  1. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    Hey guys, i got some horrrrrible axle wrap/hop. I Have a dana 60 rear, w/ a detriot 4:56gears, pinion bearing is quite loose... a home made shakle flip and 2" blocks. The shackle flip is just the stock bracket that i cut a hole in and dropped down the shackle then re-enforced the top. Stock k5 springs. The pinion angle allows the driveshaft and pinion to line up basically in a dead straight line. Oh yeah i have the 37" humvee tires, radials,, If my truck starts to break loose on pavement or anything i get horrible axle wrap/hop, its almost at the instant the tires start to spin my truck just jumps up and down violently until i hit the brakes.. which i do.
    Here is what i mean about my driveshaft..
    shackle angle
  2. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    2 words...........torque bars
  3. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    yeah i figured that.. i was more trying to figure out why, is it cuz of the shackle flip? or pinion angle? my bro has 6" all spring lift and a stock 3/4 14bolt and he gets no hop.
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I would say it is because of the blocks. They let the axle have more leverage on the spring which makes it easier to wrap. The hop is when the spring binds then releases.
    Ira
  5. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    it's because of the blocks more than anything. my truck didn't have any hop with a shackle flip and a very similar ujoint angle, but no blocks.
  6. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,991
    130
    Its because of both the stock springs and the blocks.
  7. makovai
    Jun 6, 2006
    854
    oregon city
    many moons ago i had a 86 toyota with 35x14.5 mickeys. I put a set of rancho torque bars on it mainly cause they looked cool.
    I was blown away. It was like i pulled the 4 banger out and dropped a V6 in the truck. I never realized how much horsepower was being sucked up by axle wrap until i put those bars on.
    I am currently running 39x18 mickeys on my blazer and torque bars are already in my future plans. I think they are a "must have".
  8. goldwing2000
    goldwing2000 Guest
    6" springs are very stiff, so they help eliminate wrap. That, along with your blocks, like everybody else said, is the biggest difference.
    On a separate note, it may be just the way the picture is taken, but your pinion angle almost looks TOO high. It looks like the angle is actually negative, which would get even worse when the axle wraps up. If there's angle built into those blocks, it's not helping you out any.
    I would suggest either some sort of anti-wrap bar(s), as previously mentioned, or even better would be a good set of 2" springs. Yours look pretty worn out.
  9. Steve GMC
    Steve GMC 1/2 ton status
    Dec 3, 2005
    247
    middletown,Connecticut
    i see that too, idk if its the pic or not but it does look too hight. only a small fraction though. idk if this helps but i found some degree shims on jackit.com
    http://www.jackit.com/springs/degree_shims.htm
    and they are pretty cheap too.
  10. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    The leaf pack looks thin to me. Have you removed any leaves?
  11. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    832
    Pinckney, MI
    Blocks plus crappy springs. I would suggest builting an anti-wrap bar. Do a search youll find some peoples home made stuff
  12. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    So would these work:
    Or do you need to have the "Wraptor"?
  13. 1977k5
    May 26, 2003
    9,991
    130
    Those work if your axle doesn't really articulate i.e. it won't work if you offroad your truck at all. It will severly limit articulation (flex).
    That style traction bar works *ok* for street driven vehicles.
  14. Steve GMC
    Dec 3, 2005
    247
    mike, you've seen kens, right?
    like this is what he needs.
  15. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    His shaft is really short :eek1: :haha:
  16. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    Don't hurt his man-hood... :o :haha:
  17. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    This may be a big part of your problem. If the pinion is walking around it could greatly exaggerate the wheel hop issues.
    The other possible problem is that the driveshaft yokes are binding due to the pinion angle. The pinion at the diff looks like it's too far upwards, and the natural movement when you apply power will make the pinion point even further upwards. Have you verified there are no metal to metal contact marks on the driveshaft yokes?
    I ran stock K5 rear springs with a 4" block for years with 33, 35, and 38" tires and never had any noticable axle hop issues. The only time it was an issue was after swapping in the 14-bolt rear and I did not have the shock mounts welded on yet.....any more than mild throttle caused serious axle hop. After getting the shocks installed it was no longer noticable.
  18. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Something like this will cure your wrap issues :D
  19. Steve GMC
    Dec 3, 2005
    247
    lol, thats jsut some random pic i googled to get a pic.
