axle wrap possible solution
Discussion in 'The Garage' started by m j, Jul 3, 2004.
  1. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    woah! Thats different /forums/images/graemlins/thinking.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Looks like bind city.
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    eh if you consider the center of the axle really moves, the LEAST I don't think it will be bad. When the bushing binds the leaves twist. Maybe you will wear out the spring but seeing as its not doing any suspending duties I don't see why that would really matter till they break.
  5. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    wonder if a combo of that spring with a joint like this....
    linky
    would work... that plus spring flex oughta make it less bind-able...
    j
  6. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    odly enough, it seems to have reduced on-road body roll
    Maybe because it is binding? I don't see how it can compensate for the difference in spring lenghts as the suspension cycles.
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    ? I think that it would work better if it had a shackle mount from the spring eye to the axle housing instead of being mounted solid
    that would negate any of the anti wrap effect
  8. ugly_blazer
    Apr 12, 2004
    1,214
    Ya, I thought of that after I posted and edited what I said. Some guys around here run ladder type bars from the axle to the frame and connect them with a shackle and it seems to work well, that's what i was thinking.
  9. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I know he claims it works...but I'd love to see how it performs with some real power. There is no triangulation there, and I can guarantee he is giving up some flex as well.
    Any anti-wrap contraption that uses the existing leafs as the lower link for triangulation is doomed to fail. The forward half of the leafs is what takes all the abuse already. I don't see anything there that'll prevent them from deflecting into and 'S' shape under hard power.
    Rene
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the fact that the 'third' link is a foot above the other 2 links is going to limit wrap
    you know I do not believe anyones claims /forums/images/graemlins/smile.gif
  11. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    And how solid are those two lower links? An anti-wrap bar is meant to save the springs from having to deal with housing rotation...not use the weakest part of the suspension as a structural link for triangulation.
    It's a poor design IMO.
    Rene
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    are you samiliar with the Caltrax linkage and its effect on SS drag racing?
    the housing cannot pivot as freely with the third spring mounted up high like that
    I am not selling this idea, just thought it was a novel lowbuck approach that I think works
  13. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    i dont think its optimal either, but it is cheap and it might work for those of us who don't have a blown BB and aren't in love with the skinny pedal. I like crawlin slow and easy and my engine is an almost entirely stock 350. I hardly ever "hammer down" if I can avoid it so maybe something like this would work for me...
    Those X-joints can rotate 30 degrees before they bind at all, and then the spring should have some flex in it... from the centerline of the axle thats quite a bit of flex. Guy who sells em on pirate says you'd need a spring with 2.5" ID for the joint to fit though... local spring shop might be able to do something like that relatively cheap...
    j
