axle wrap
Discussion in 'The Garage' started by K5Greek, Aug 5, 2006.
  1. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    k im pretty sure i have axle wrap..everytime i come to a light or something it feels like my rear end shifts..so im pretty sure i have some
    my question is, is axle wrap a problem that needs to be solved or it will cause damages? or is it one of those problems that just annoys you?
  2. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    axle wrap is found on (hard) accelleration not comeing to a stop.
    check your u-bolts, springs, and u-joints and any slip joints in the drive shaft. dry slip joints in the shaft can bind and unload.
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Not to start an arguement here, but I think it is possible to have a form of axle wrap when braking. My K1500 has a 5" block, and when I put the truck in forward or reverse with the brakes on the axle will move. It feels like the axle moves rearward when I brake, and my friend says it looks like it too when I'm stopping. When the truck finally stops the axle will move back forward. Blocks suck.
  4. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    Ok your right there, with the physics of it. but in reality if you're seeing some axle wrap on braking your leaves would be pretzels on acceleration. soooo we'd be talking about the big problem not the little problem wouldn't ya think.
  5. divorced
    Jul 20, 2004
    5,115
    Ya, my springs go crazy when accelerating. If I nail the gas from a stand still, the springs will wrap and then unload and shoot the truck off.
  6. otisringle
    otisringle 1/2 ton status
    Aug 2, 2005
    148
    california
    My truck does the same thing at stops. The backend feels as though it drops a little or something. Im replacing the springs(get rid of the sag) and bushings and ubolts in hopes this will end. A buddy of mine had the same thing happen to his truck and it was fixed after he got new springs and bushings and what not...
  7. K5Greek
    Nov 25, 2005
    2,054
    Vineland, NJ
    k then since i have no blocks and axle wrap doesnt usually occur during braking ill check out the other stuff.
