Axle Wrap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by loudandproud, Oct 3, 2000.
  1. loudandproud
    loudandproud 1/2 ton status
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    How do you prevent axle wrap?? The guy at the shop said I need to get traction bars or something. My truck is lifted with blocks, is that bad? Would getting new leaf springs be better, and prevent axle wrap??? Thanks
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Get some Trac bars. Rancho makes them. Also there are some in JC Whitiney for $70. Track bars also help a lot in giving more traction to the rear end. Good for hill climbing.
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Yeah, the blocks make it worse. You'd have less axlewrap (or so I've herad) with just stiffer lift springs.
    You can get trac bars (I've seen some that mount to the axle with ubolts and then just bolt to the frame, so no welding) but they will limit rear axle articulation. No biggie is you are a mudder (like me) and not a rock crawler, but I wouldn't do it to my mud/trail rig because I still flex out when I climb over big stuff.
    If live where there are lots of rocks, you definitely would not want to do it.
    -- Mike
  4. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,790
    99
    Paducah, KY
    Look at ORD's shackle flip. It cures it by alowing you to lift 2.5" or 4" and still use your stock springs. www.offroaddesign.com Hope this helps.
    1992 Blazer Sport, 350 TBI, 4L60, 3" Gibson, K&N, 3" Rancho, 285/75R16 on 16x8 Baja's [​IMG]
