axle ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by baldbandit, Jan 4, 2001.
  1. baldbandit
    baldbandit 1/2 ton status
    Jun 16, 2000
    282
    Marshall TX
    I have a 3/4 ton Dana 44 and 14ff that has been sitting for a LONG time. What do i need to do/replace before putting them in service? I know i need to change diff fluid and i need new lockers (the old one are dry rotted). Anything else?
    thanks
    baldbandit
  2. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    What the beeeeep. Is a dry rotted locker. Never heard that one before.
    "IF YOU'VE NEVER BEEN STUCK.....YOU'VE NEVER BEEN WHEELIN"!!!
  3. baldbandit
    Jun 16, 2000
    282
    Marshall TX
    I meant dry rotted locking hub. The factory hubs had plastic centers that dry rot over time.
    baldbandit
  4. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    I'd say repace every thing from brakes to seals. If it's been sitting awhile the seals dry up and allow moisture to get in.
    my .02
    Bill Innes
    88' Jimmy
  5. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    When I plucked my axles from the jyard, I put them on with only replacing the seals that were bovioulsy bad or the ones I messed up. They don't leak at all.
    I DID replace the fluid, obviously. Cheap insurance.
    I went through the brakes. Converted the rear to disc and put on four new rotors, four new calipers, and all new brake lines. It was a little pricey, but so is my truck insurance, so I do what I can to avoid running over imports.
    --- Mike
