??axle??
Discussion in 'The Garage' started by nicotine, Mar 7, 2004.
  1. nicotine
    nicotine 1/2 ton status
    Jan 11, 2004
    116
    okay i know it would be better to run the 14bolt but why not get a set of moser axles for my 12 bolt? i know the 14b would be way better than the 12. but if i ran the 14 i would want 3/4 ton front also plus added cost or new wheels and tires. thats alot of money. anybody run these axles i read the review but i want some live feedback. And what is the biggest size tire would run on a 12 bolt with good axles?
  2. bushmaster
    bushmaster 1/2 ton status
    Jun 1, 2003
    146
    ct
    nic the 12 bolt doesnt hold up well with large tires ive blown up 4 in my blazer the spiders and pins explode under hard acceleration and full throttle 2nd gear shifts ive switched to a dana 60 and for four years i havent had to touch anything i was running 38.5" and 35" tires if your driving style is "normal" 35" tires should last you a while with the 12 bolt
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    One of the big benifits of the 14ff is that the weight of the truck and the strain is on the axel HOUSING, with the 12 bolt, the weight is all on the axel shaft itself. 10 bolts and 12 bolts are known for breaking axel shafts. Even if you go with a Moser or any aftermarket axel, The axel shaft is still taking the brunt of the load. You could go with the Warn axel shaft AND full floating kit, But at 600.00 it makes the 14ff a CHEAPER option! With a little grinding on the case, you won't lose much ground clearance.
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Simple fix. Get the 14 bolt FF with matching gears to your front, and get the 8 to 6 lug adaptors so you don't need new rims. /forums/images/graemlins/deal.gif
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    also truck 12 bolt have tiny small pinion stem diameter, the bearings commonly burn up and come apart,
    i would stay away from a 12 bolt unless is high ratio and is with small tires and not driven any other way cept light daily driving, you would be better off with any other axle than with a 12 bolt truck axle for anything other than normal driving
    for the most part
  6. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    I don't think the 8 to 6 lug adapters would work. The center hole of a 6 lug wheel isn't large enough to fit over the 14 bolt's hub. If I am wrong, someone please let me know cause that's what is holding me back. I was also thinking about getting a 14 bolt semi-float that is 6 lug, it is obviously not as good, but plenty strong enough, right? /forums/images/graemlins/truck.gif
  7. nicotine
    Jan 11, 2004
    116
    i was looking into the adapters but with only having 33-35 inch tires the ground clearence on the 14 bolt would be horrible. Also i have to change the gear ratio in the 14 bolt because it is out of a van. another question is with the adapters on a van rear end it would stick out a litter further than the front if this is the case how much?
  8. Ryan B.
    Jul 18, 2001
    5,693
    CA
    When you run those adapters you take the 14ff hubs and axles to have the ends turned down.. this way the hole in the 6 lug rims will fit over the hub. /forums/images/graemlins/thumb.gif
  9. nicotine
    Jan 11, 2004
    116
    yes but with the van rear end how much wider will the back be?
