axles and lockers?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BPCRJ, Nov 22, 2000.
  1. BPCRJ
    BPCRJ Registered Member
    Apr 29, 2000
    12
    what are the ultimate axles for a blazer with alot of hp. and 44in tires and also i plan to purchase some type of locker for better traction for front and rear end, what the best kind for a blazer used 99% off road only
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Rear 14 bolt, front Dana 60. Can be found on any 1977-1987 one ton 4x4 GM truck. Also, get Detroit Lockers front and rear. Avoid the temptation of the "flavor of the month" lockers, i.e. the Air Locker, which are prone to failure over time, and have delicate air lines hanging around that can be snagged. Better to install a Detroit and forget it...just make sure its got oil, that is all the maintenance it ever needs.
    ken
  3. FLWIV440
    FLWIV440 Registered Member
    Nov 21, 2000
    32
    I just installed powertrax no slip system in my 12 bolt, very impressed,no popping,no noise,no clutches to screw with.Detroit's are good,but am very impressed with these. Drive my K5 70% off road.
  4. BPCRJ
    Apr 29, 2000
    12
    where can i find a web site that explains the differences of all the different type of axles?
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
  6. BPCRJ
    Apr 29, 2000
    12
    what about a dana 70 with detroit locker in the back and a dana 60 with arb air in the front
  7. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I was planning on a ARB in front, because I heard the turning radius is tighter with an unlocked front end. ARB allows you to unlock, Detroits are always locked. So, with that said, please give me more opinions on this subject. I'M SO CONFUSED!!!!!
    blazen91
    Protect the land FOR the people
    <font color=red>Not FROM the people</font color=red>
