axles and wheels and junkyards OH MY!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RubberFloorMat, Jan 18, 2006.
  1. RubberFloorMat
    RubberFloorMat 1/2 ton status Premium Member
    Dec 12, 2004
    386
    40
    Oklahoma
    so ok what year and models shoud l look under for a Dana front and 14ff rear???
    how bought a 83 3/4 ton 4x4??
    and will it still be a 6 bolt or will i need new rims??
    should i get the leafs as well?
    i dont have internet right now or id look on my own.
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    An '83 came stock with a 10 bolt front and a 14 bolt FF rear, and they were 8 lug axles. The 10 bolt and the dana 44 are close in strength, but there are many more parts around for the 10 bolts.
  3. RubberFloorMat
    Dec 12, 2004
    386
    40
    Oklahoma
    so what year model's should i look at for axle upgrades.
    im not going any bigger than 35"s and have some decent wheels already, if i build up the 10 bolts can it handle it?
    mild trails and some mud, but a mostly street vehicle, hunting and fishing etc...
    have a 4" lift and 33"s now.
  4. divorced
    Jul 20, 2004
    5,115
    I have wheeled just fine in the mud with 40's on a 12 bolt, and many times with 35's on a 10 bolt. Every now and then I would break one, but that's only after much abuse, and they were easy/cheap to replace. For your intended use, I would think a stock 10 bolt should hold up fine for quite a while. I wouldn't spend a great deal of $$$ to build up a 10 bolt, just run it till it breaks and replace it. You can also get a 14 bolt semi-float with a six lug pattern that should be plenty strong. I don't know what years/models the SF axles came in, someone else will have to help with that.
