axles, axles!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by santana, Jan 14, 2003.
  1. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    Can anybody explain why the rear axles are narrower than the front (10 bolt)? Also is there an axle that is the same width as the front or a way to extend it to be the same width?
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
  3. nevercomplete
    nevercomplete 1/2 ton status
    Dec 25, 2001
    309
    Beaufort, South Carolina
    I've heard a few theories about why the rear axles isn't as wide as the front, but I don't know the real reason. A 14bolt ff out of a van is 3 inches wider than one from a truck. Again I don't know why.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i have to bet that its to allow better steering radius clearances
    rear axles are all same WMS to WMS no matter if C or K, i think the wheels up front need to be farther away from frame rails to prevent sidewall contact during sharp turn but GM didnt want to have to have two different length rears, the 2wd axles work fine, vans are wider than trucks anyways so axles and lower arms and stab bars are also, thats just how it has to be or it wont work
  5. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    As far as I have read it is to improve the turning radius. Van rear axles are wider and would make a good fit. Before you put wheel spacers on I would do a search here to see some problems that other people have had with them, their wheels coming of and the spacers coming loose. Any way, if you buy spacers retorque, retorque and retorque.
