Axles Delima?
Discussion in 'The Garage' started by Tweetysuarus, Mar 12, 2004.
  1. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Would you finish upgrading D44 &12 Bolt that already has Detroit lockers and 4:56 gear sets. Upgrade with Warn axles and CTM U-Joints in the D44 and Superior Axles and disc conversion in the 12Bolt or would you opt to buy the D60 & 14BFF and do a full build up on these axles? I do intend to use this rig for various types of trail runs. So far it has served me well on the trails I have been on. Feedbacks would be greatly appreiciated as this is a very spendy project.
    Thanx,
    Bill
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Tell us what tire size you are after?
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I am strange, I would run the 12 bolt until it died. I only say this as I had to get my DD (only truck actually) back on road quick. So I pulled a 12 bolt from a yard. I did buy a locker too. So with this much into it I am running it until it dies, then upgrade. I never seem to find the 1 ton deals other members do, I have looked in yards too. Then you have wheels, seals, brakes , gears ratio matching. /forums/images/graemlins/k5.gif
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    It all depends on what the biggest tire you will run and what type of wheelin you do...
  5. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    I'm running 38's now, But my intentions are to go to 39's or 42's?
    Bill
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Those are huge tires. I take my post back. Get the 1 tons . Sell me the 10 b front locker. /forums/images/graemlins/thumb.gif
  7. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    What 10 bolt? I'm running second design D44 up front?
    Bill
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    My bad. Brainfart. But still, those tires are HUGE /forums/images/graemlins/waytogo.gif
  9. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    too big for 1/2 tons in my opinion, but if you beef them up with shafts and u-joints and stuff I think they might hold up, but if you go any bigger your going to break them sooner or later. Maybe even with 38" tires you would probably break them eventually no matter what you do.
  10. CK5
    May 19, 1999
    21,623
    701
    CO
    Bill
    I ran into this problem a few years back, I had the lockers and gears but before I spent any more on shafts, joints etc, I cut my losses and did the 1 ton stuff, best thing I ever did.
  11. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Thanx for the input guys!
    Bill
  12. hardcore71
    hardcore71 Registered Member
    Nov 21, 2002
    86
    Weare NH
    I just mentioned this in another post, ORD shafts and CTM joints $984 plus shipping. 1986 D60 4.10 complete $850. And you can still sell your axles.
  13. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    With 38's and the plan to go bigger 1 ton all the way. A built set of 1/2 tons or 3/4 tons could probably survive with 38's for awhile. If you have a good mellow driving style and you are smart you could probably make 38's work on a 1/2 front. I am going to try once I get the $ for the 37's or 38's. I know I am going to snap axles and such but oh well. I am going to see how well the big tires and 1/2 front works.
    I have gearing so I don't have to use the throttle to jokey over and around things. Just let the motor crawl around. I don't think that there is anything that I could realistically climb or crawl that my truck wouldn't crawl at 1000 RPM or less. I haven't had any hardcore trails under my belt but I have crawled it enough to know that 800 RPM is plenty of torque to crawl most anything in my truck.
    Hopefully with the low RPM I can crawl at I won't have to be changing front axles all the time. I have 3 full sets of spare axles though just in case I am wrong. /forums/images/graemlins/dunno.gif
    Harley
  14. cuzinjay
    cuzinjay Registered Member
    Feb 13, 2004
    62
    rome ny
    If you are happy with your 4.56 then I would say keep what you got.
    I wouldn't sink too much money into the 12bolt.I think I would build a 14bolt for the rear if you have problems.
    The 44 lasted for me with my 39.5 tsl just fine.Yes I broke some axle shafts but I can replace a lot of shafts for the price of a d60 built to match.
    I might wheel hard once a week or once a month in the depends on work,but for me 2 or 3 shafts a year isn't worth the cost of a d60.
    I know every on thinks a d60 is the answer but cost is the desiding factor for me. /forums/images/graemlins/deal.gif
