Axles in 79
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txfireman110, Jan 2, 2004.
  1. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    What axles would you expect to find in a 1979 Chevy 1 ton 4x4 P/U???
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    14bff and a d60 i believe..
  3. one ton burb
    one ton burb 1/2 ton status
    Nov 15, 2003
    119
    Ontario, Canada
    it will be a 14 bolt full floater if it is a srw version and a dana 60 front end. but watch out for the one ton full time trucks because they have a np 203 and a full time dana 44 front end.
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I have a '78 K30 that was full-time, and it has a 60 with drive flanges (no lockouts). I have never heard of a 44 front in any K30.
  5. Confedneck
    Nov 1, 2002
    5,236
    before the D60 came out.. one ton trucks had d44 front ends.. /forums/images/graemlins/thumb.gif
  6. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Yep, most people don't except it but there was a 1 ton rated 4x4 before 77' with a D44. /forums/images/graemlins/grin.gif
  7. Confedneck
    Nov 1, 2002
    5,236
    see, i know a few things..people should "accept" my word as gold, from now on.. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  8. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    /forums/images/graemlins/shocked.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  9. sandracer0004
    sandracer0004 1/2 ton status
    Jun 24, 2003
    108
    San Jose, CA
    well i have a D44 out of a 76 chevy, it came with a 14bff does that make it a 1 ton? a buddy of mine was saying it was a large hub D44? he has a 1 ton with a D60 and told me that i had the better D44? not sure? how would you tell?
    i always thought d44 where for 3/4 tons.
  10. Blazer1970
    1,600
    Old Mission, MI
    The first factory K30s were made in '77, and they came with Dana 60s. Prior to that, any one ton 4X4 was an aftermarket conversion, and they probably did have Dana 44 fronts.
  11. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ]That is probably a D44 out of an early chevy 1 ton 4x4.
  12. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    It's not the front axle that determines if it is a 1 ton or not, it is the GVWR that distinguishes that. Most of us don't consider them one tons just because it didn't have a D60 under it but that isn't what matters when it comes to vehicle weight class, it's the amount of weight it can haul/tow. I agree that it doesn't seem to be a 1 ton but all we wan't iss heavy parts and get used to seeing only a D60/14BFF combo as "1ton" but "1ton" has to do with weight handling and not axle combos.
  13. Confedneck
    Nov 1, 2002
    5,236
    well if the 14bff is original, look at the shock mounts.. if they are both on the same side of the axle housing, its one ton..
  14. one ton burb
    Nov 15, 2003
    119
    Ontario, Canada
    [/ QUOTE ]the one ton I'm taking about, dose have a dana 44 front axle with the bolt on drive flanges and it was also a duellie hub version not a srw it also has a dana 70 rear axle instead of the 14 bolt ff.
