axles under a '74 C-10 4x4
Discussion in 'The Garage' started by Muley, Nov 4, 2002.
  1. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    axles under a \'74 C-10 4x4
    Anyone have a remote guess on what type of axles I might find under a truck of this year?
    Any educated guesses would be great.
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Re: axles under a \'74 C-10 4x4
    C10 would have an independant front and a Corp 12 bolt rear w/5 lugs
    K10 would have a Dana 44 front and Corp 12 bolt rear w/6 lugs
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    c-10 means 2wd. But since you are saying 4x4, it is a k-10.
    Previous post is right.
    I think it will have the external hub d44. Someone correct me if I'm wrong.
    -- Mike
  4. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    unless someone converted that thang to 4x4, but i dont see why, unless they were uncommen in 4 By in that area.
  5. Muley
    Sep 26, 2002
    364
    Eagle Mountain, UT
    Sorry about the C/K screw up. Next time I will just play dumb and say 1/2 ton PU. /forums/images/graemlins/rotfl.gif
  6. Muley
    Sep 26, 2002
    364
    Eagle Mountain, UT
    Assuming that it has the Dana44 and 12 bolt. I know the 12 bolt is better that the 10 bolt I have currently. My question though, Is the Dana 44 a better front axle than the 10 bolt I currently have under my 85?
    How would I tell for sure that the truck has a Dana up front?
  7. kennyw
    Jun 9, 2002
    13,224
    94
    The Dana 44 is marginally better than the 10 bolt up front. Not enough to warrant swapping unless you need it to match the gear ratio with the 12 bolt when you swap it in /forums/images/graemlins/grin.gif
