axles
Discussion in 'Other Rides' started by 84gmcjimmy, Dec 20, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Alright, I don't have one yet, but eventually I want a Nova or Chevelle...
    my question is...
    can you put rear truck axles under a 2wd truck or car? Or is there a difference between the 2? It's just more common to see 4x4 12 bolts, than 2wd ones. Also, besides the ford 9" and a GM 12 bolt, what are other common axles to put in muscle cars, or cars with big TQ and HP numbers?
    Thanks!
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    The big block mopars used dana 60's but those are rare, hard to find, but i see no reason you couldent find a regular rear 60 to use, you would need a SF one though, so as to not have a big ole hub stickin out, pick up a HotRod mag, they will give you all kinds of ideas to use on your car:xmas:
  3. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Any specific HotRod magazine? Or just anyone I can find at the store?
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    You cannot use a truck rearend under a car. It is too wide IIRC. I would use the stock 10B car rearend because it can handle a lot of abuse. A car 12B is also a good rearend.
    You could go to a ford 9" built by Currie or somone and you won't break it. That is probably the best car axle out there. Currie also makes custom D60's. Expect to spend 2.5K$ on a custom 9" or D60 from them.
  5. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    A properly built 10 bolt will hold up pretty well on the street. When you start running slicks at the dragstrip is when the 10 bolt has problems. The lighter the car, the less rearend breakage you will have.
  6. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    the car 12 bolt is completly different than a truck 12bolt. the car 12 is ALOT stronger. i think most car 10b have 8.2" ring gears. not a very strong unit. can be made to handle a decent amount of power, but if your going to spend any money on building up a good rear end... get a 9" they are the ultimate drag rear end. even the 8000hp top fuel dragsters use a rear end based on the 9".
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay I will keep my eye on 9" fords, and maybe 12bolt CAR axles.
  8. spartan4x4
    spartan4x4 Registered Member
    Nov 30, 2004
    18
    SC
    not to hijack, but what is the difference between a 2wd 12 bolt and a 4wd 12 bolt?
  9. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    the mounts are different, and probably the width, then depending on what they came out of, 6 lug, vs 5 lug
  10. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    From what I can remember, the only thing that's the same is that they both have 12 bolts holding the rear cover in place.
  11. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Woah! So there is a HUGE difference. I learn something new everyday :)
  12. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    My post referred to the comparison between car 12 bolts and truck 12 bolts. I have never compared 2 vs 4wd on trucks, but the last time I looked, the part #s for ring and pinion sets do not differentiate between 2 and 4 wd.
  13. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Yeah I know you were talking about 12bolt car/12bolt truck axles.Thanks for the info :)
  14. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Nothing , except the lug pattern and some years have wider brakes . My 10 bolt truck brakes , and the six lug shafts from a 4wd 12 bolt were all I needed to install a 5 lug truck 2wd 12 bolt in my Blazer:xmas::xmas::xmas:
  15. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    shaft length was no different between 2" and other widths of shoes on truck 12 bolts and 10 bolts, 70-up they were a little over 31" long regardless of brakes
    and 12 bolt truck being 4x2 or 4x4 didnt matter, they are all the same 8.875" ring gear equipped axle but there are six different load rated truck 12 bolt axle units, depending on exact model and year, van, pickup, panel, burb, etc., anywhere from 2800 to 3600lbs rated, mostly all depending on brake size
    same housings same carriers same shafts just different backing plates and shoes and parts
    car 12 bolt is a whole different thing yes, last in 72
    big car axles like 70s olds delta 88 and such are really super close to same width as full size truck axles btw
    so much so that you wouldnt even notice
    cars like malibu and nova and camaro are narrower however
    dont go with a truck 12 bolt
    go with a 10 bolt car truck, 12 bolt car, or dana 60 mopar and such
    most any will require welding on axle tubes to make bolt in
    there are many web pages out there on this subject, some with illustrations and swap info,
    go find them
    good luck
  16. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Thanks for the info. I'll start searching tonight
  17. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    What year are you lookign at? Leaf or coil sprung? Good luck finding a 12b, if you do its gonna be some bucks. 3 on the tree is right, a proper built 10b should be fine, I wouldnt wast time with a 9" either.
  18. JDNobodi
    JDNobodi 1/2 ton status Premium Member
    Oct 9, 2002
    3,008
    197
    Santa Maria, CA
    I thought car 12 bolts have larger pinion bearings than the truck 12 bolt.
  19. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    The years I am looking at are 67-72 Novas or chevelles. I don't know, but probably coil (those are softer, right?) So I would have better luck building up the 10 bolt that comes with it, rather than looking for a 12 bolt?
    Whats wrong with the ford 9"?
  20. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    First of all its called a 12 bolt because thats how many bolts hold the ring gear, not the cover bolts. 10 bolts were usually 8.2 ring gear, but in decently powered cars they are 8.5. The older 12 bolts in cars and trucks are almost identical except for mounting locations. The only difference are the axle shafts being 5 lug or 6 lug, but they are still interchangeable with another. I dont remember the years of interchangeability of hand, but want to say the late 70's and earlier axleshafts are interchangable from car to truck. 12 bolt is a great choice for a chevelle or nova. If the car came factory with a bigblock you should already have one under the car. What makes the 9" stronger than a 12 bolt in some circumstances it the fact that the pinion is supported by bearings on both ends instead of one like the 12.
