Axles
Discussion in 'The Garage' started by ThreeBills$, Apr 4, 2005.
  1. ThreeBills$
    ThreeBills$ Registered Member
    Feb 8, 2005
    11
    colorado
    Does a 14 bolt full float axle come in 6 lug?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    not factory
  3. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    You can convert them using a 8 to 6 lug spacer adapter or by milling down the hub and axleshaft and redrilling the hub for the 6 lug pattern I believe.
    Harley
  4. ThreeBills$
    Feb 8, 2005
    11
    colorado
    Then can I get heavy duty axles that fit in my 10 bolt front end that are 8 lug?
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Front axleshafts have no wheel lugs on them. The hub assembly has the lugs on it. You can convert a 6 lug front axle to an 8 lug front axle. The actual strength of the axle is not increased at all. The only difference is it has the 8 lug bolt pattern.
    Only semi-floating rear axles (10 bolt, 12 bolt, 14b semi-float) have the lugs intergral with the axleshaft.
    A 14bff axleshaft does not have lugs on it. The hub has them like. Front axles are also the full floating design like 14bff's.
    Harley
