axles???
Discussion in 'The Garage' started by aztook, Jul 3, 2005.
  1. aztook
    aztook Newbie
    Jan 12, 2003
    oklahoma
    I have an '84 k5. I want it to be a reliable trail rig, not hard core. Just family fun. Looking for advice on weather to strenghten my existing axles, or upgrading to 3/4 or 1 ton. Any advice would be greatly appreacated. Iam also on a very tight buget, so money is a big obsticle.
    thank you
    Steve
  2. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    Upgrades
    If your not going to get silly with it,with huge tires and rockcrawling, you can basically leave it stock, and put some $$ into making the engine a little more powerful, which usually equates into better gas mileage as well. Stuff like better air intake, exhaust mods, maybe an ignition system. Ther's other stuff you can do as well, which will become more apparent as you own it longer and drive it more.
  3. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    If you can round up a set of 3/4 ton axles, they will be very reliable considering that you prolly won't any bigger!
  4. unclematty
    Jan 24, 2003
    3,164
    SLC UT
    But DO NOT HANG OUT HERE TO MUCH AS YOU WILL CATCH THE BUG BAD!
    THEN THERE WILL BE LOTS OF :hack: :hack: :hack: :hack: :weld: :weld: :weld: :grind: :grind: :grind: :deal:
  5. aztook
    aztook Newbie
    Jan 12, 2003
    oklahoma
    Eventually it will have a 4-5" lift with 35s
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Don't get in a rush. Post up on local farmer/rancher websites with free wanted adds that your looking for a non running K20 or K30 for parts. You just might hit the jack pot. Usely you can buy a whole non running parts truck pretty cheap. Strip it for everything you need, and any good parts, and have the rest hauled away.
  7. LongIslander26
    Jun 25, 2005
    256
    HEY!! Good idea!
    That's a good idea! I'll go hang something like that on the bulletin board at the feed store up the street. Good thinking! (Take 5 dollars out of petty cash)
    :waytogo:
  8. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    biggest concern is the rear axle, find a 88-96 2wd 3/4 ton and pull the 6 lug semi-floating 14 bolt for your blazer, regear everything to work with 35's and be done with it
  9. LongIslander26
    Jun 25, 2005
    256
    SF 14 Bolt
    Those 6 lug 14 bolts may be a little hard to find, I know I'm still looking for one here in AZ. Just a thought, but a solid swap if you can find one.
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Thats how I found my 76 K5 when I was looking. I try too stay with-in a 500 mile limit, but it's really up to you how far you're willing too travel for the stuff you want.
  11. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    If you could be happy with 33's then you could leave the axles alone.....
