Axles
Discussion in 'The Garage' started by MagnuM4WD, Oct 12, 2006.
  1. MagnuM4WD
    MagnuM4WD 1/2 ton status
    Jul 26, 2006
    138
    Bucureşti - România
    Hi! Can you tell me, there is any kind of difference, between front axle, from Blazer (6 lug, 2 shock absorbers) and front axle from Suburban (8 lug, 4 shock absorbers), like shock absorbers brackets, brakes, max. load capacity, bearings, lenght, etc.? Bouth have diff. on the passenger side, 3.73 end ratio and they are GM 10bolt. Mine, have 1760 mm lenght (between flat surfaces, where the wheels are mounting). Just curious!
    I find also, a 14bff, from a 3500 pickup, with the same end ratio (3.73) and I wish to replace, my 14bsf, with that. Can I do that, with no problems (yokes, drive shaft, springs position, etc.)? My 14bsf, have 1700 mm lenght. What lenght have 14bff? Is from a 3500, with single rear wheels, 7.4L gas engine (454 cid) and MT.
    I ask you, because, the parts, are on the other side of the country (600 km) and I did't see them, yet. The owner, have a K5 (from where is the front axle GM) and buy the 3500, for engine, MT and front axle (Dana 60).
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    if the 3500 has a dana 60, dont waste your time swapping in another 10 bolt, put the 60 inand the 14bff, they will both bolt directly to your spring plates, you will need to get different ujoints to make the axles work though
  3. MagnuM4WD
    Jul 26, 2006
    138
    Bucureşti - România
    About 10bolt, it was just curiosity. I can't have the Dana 60, because the owner use it, on his K5! All I can take, is: front GM 10 bolt - from K5 (just for spare parts - if is like the one, I have it on my truck, already - for moment, mine, is work fine) and, rear GM 14bff, wich, I believe, is better (stronger) then my GM 14bsf and I wish to use it, if it match. So, I'm really interested on that 14bff. For this axle, I need different U-joints?
  4. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    The 10 bolt will bolt in with no problems, however the perches on a 1 ton axle are 1" off. A 3/4 ton 14 blt ff with bolt right in but the 1 ton has the perches 1" off and the shock mounts are reversed. Width and all are the same though so if you can cut and weld you can just move the perches and mounts.
  5. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Go for it.
  6. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Partly correct. Your right about one part....if there is a D60 up front on the 1-ton, then dont swap in the 10 bolt from the suburban. The D60 is MUCH stronger and more desirable.
    As far as the 14ff...it WILL NOT bolt directly to your spring plates. The front D60 will bolt right up (with the exception of the u-joint), but since its a 3500 (1-ton) truck, the 14ff will need to be modified. The spring perches on a 3500 1-ton are 40.5" from spring center pin to spring center pin. Our trucks (1/2 ton) are 42.5" spring center pin to spring center pin. Therefore, the perches on the 14ff will need to be moved out 1" on BOTH sides. The shock mounts are also opposite on the 14ff, and will need to be cut off and reversed. Your also going to need new u-bolts (if you cant get them off the donor truck), and new u-joints. The 14ff uses a bigger u-joint than the 10 bolt or 14sf. You can buy a conversion u-joint....but the easiest thing to do is grab the driveshaft off the 1-ton donor truck and have a driveshaft shop cut off the yolk and weld it onto your driveshaft.
    You will also need to grind some metal off of the top of the brake calipers on the D60 if your trying to use 15" wheels.
    -Harrison
  7. 87BrnRsd
    Apr 21, 2003
    2,457
    As stated...the 1 ton axle's spring perches are 2" off. 1" on BOTH sides....
    -Harrison
  8. MagnuM4WD
    Jul 26, 2006
    138
    Bucureşti - România
    You make me confuse... a little... That axle - 14bff, from pickup double cab 3500, I want to put it on a Suburban 2500, not on a K5.
  9. MagnuM4WD
    Jul 26, 2006
    138
    Bucureşti - România
    I HAVE A 14BFF, FOR MY TRUCK!!! I buy it and I bring it home!!! :saweet: :saweet: :saweet:
    Tanks for your support! :burb: :crewcab:
  10. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Good deal. If you have anymore questions, I'm sure we can find an answer for you.
  11. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    partially correct. you will need new u-bolts, DO NOT REUSE THEM! they're too cheap to worry about the stockers stretching out and coming loose. if they come loose, you're in for a hell of a ride. doesnt matter if its a steer axle or not, because with loose u-bolts, they both become steer axles, with no way to conrtol them.
