  1. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    Well my 88 has 30 spline axles ,I found out because the bearings decided to destroy them,So im going to try the axle saver bearings tommorow.Anyone try these?I guess ill soon find out how they work.
  2. It would b a good time to try some moser axles if this dont work.I dont know about the axle saver's never used them.
    Good luck,let us know how it turns out.
    IF IT AINT BIG IT AINT BAD!!!!!!
  3. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
  4. coopertwpk
    Mar 18, 2000
    478
    axle saver bearings relocate the bearing away from the wear spot and the seal is part of the bearing housing the seal sticks out about a 1/4"from the housing and it went back together so well see.
