Axleshaft ID?
Discussion in 'The Garage' started by Hossbaby50, Oct 26, 2003.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Today I became all confused about how to tell 10 bolt axleshafts from D44 axleshafts. I was told that 10 bolt stub shafts have the 2 grooves for the 2 snaprings that the 10 bolt uses.
    Did D44 axleshaft have the 2 grooves too? We found some axles in the yards today that had 2 grooves and some that had 1. I assume the 1 groove is D44. I know the stubs are the same (except for maybe the groove number) but is there any easy sure fire way to tell D44 inners from 10 bolt inners? Anything at a glance, are there a different number of splines? I know 10 bolts are 28 spline (except 88 and later have 30) Thanks
    I am really confused. I saw one truck with D44 that had a 1 groove axleshaft on one side and a 2 groove on the other. I am confused /forums/images/graemlins/confused.gif
    Harley
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    find the lengths and use a tape measure....Not much help....
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    The outers interchange but I dont know how to tell the inners apart.
    Maybe the legnths on the inners is different?
    A 44 long side inner is 37" and the short side inner is 19 3/8".
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    D44's could have either one or two grooves on the stub shaft. The shaft on the top is my '71 D44 and the bottom shaft is my '77 D44. Easy to see in the pic.
    Like the others have mentioned, the only way to tell that I know of is to measure the inners.
    Here are the shaft lengths as provided by Wes in his D44/10B bible.
    The D44 shafts measure: right - 36.13"
    left - 18.31"
    10B shafts measure: right - 35.46"
    left - 19.15"
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ok, I am going to throw a monkey in the wrench.
    I have seen 3 different types of outer stubs now that I think about it.
    They are:
    1: One groove on the outer
    2: Two grooves on the outer (like the second shaft in your picture)
    3: Two grooves on the outer but the second groove is farther back then the one pictured. I know that the second groove farther back is where the snapring for Auto hubs goes on a 10 bolt.
    Did D44's ever use a stub like #3?
  6. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Hmm.....well, I don't have an answer to that question. I would speculate that D44's would not have that further-back goove since they never came with auto-hubs(that I know of). I do know that my '71 D44 uses the outer-most groove (the only groove) for the manual lockouts. The '77 D44 was on a full-time 4wd truck. The slugs were held on using the inner-most groove. /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    My '74 D44 also has 2 grooves on each side, but there is NO snap-ring holding anything on /forums/images/graemlins/thinking.gif
  8. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Hmmm.....more monkeys to throw into the wrench. /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  9. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    I was thinking the same thing, 3???
    this is getting confusing /forums/images/graemlins/confused.gif
