Axleshaft questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hossbaby50, Dec 29, 2001.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I just got spare axleshafts for the front 10 bolt. They have this small backing plate on the stub shaft. They are pretty beat up, so what are they, do I need them, and where do I get them? Also are there any bearings that are supposed to be on the shafts?
    I am getting spare axleshafts for the rear also, and was wondering if there are any bearings or backing plates, etc that need to be pressed on or is the shaft all I need? Thanks
    Harley
    My Chevy isn't broken, its just out of gas.
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    "They have this small backing plate on the stub shaft"
    it is a seal surface, I would say you need to find some.
    "are there any bearings that are supposed to be on the shafts?"
    Nope, the forgotten bearing is inside the spindle.
    for the rear I am thinking just the shaft
    formerly 77chev
  3. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    Those dust shields are still available from Spicer. They are lightly pressed on and really easy to change.
    '70 K-20 San Diego, CA
    I know, I can't spell!
  4. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Unless they are really trashed, they can usually be straightened after removing them. Or just take the ones off the blown shaft when putting in the spares. Makes them easier to store sometimes, too.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  5. sinchphoto
    sinchphoto 1/2 ton status
    Mar 7, 2000
    366
    Southern California
    on the front those are dust shields and no bearings go on there. the bearings are on the spindle inside your discs. on the rear there no bearings also. the bearings are on the axle housing. I have an extra set of rear axle shafts im gonna get rid of if you interested let me know.
