AZ emissions for an 78....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Impex, Mar 24, 2000.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    This 78 im looking at to buy does not ahve cats or any smog equipment in the engine. So is this right i heard that they did not have cats untill 79 is this true and will i pass emissions with this setup oh and it has dual exhaust.
    Thanks!
  2. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    If you are in Phx or Glendale i'll be working on the 79 this sunday...i have all the factory manuals so if you want to take a peek at what was required in 78 your more than welcome...otherwise it will take me some time to grab the manual and scan a copy of the emission system for 78...
    AZBLAZER
    1979 K5
    1976 K5 Chalet
    1972 K10 Suburban
  3. OLDSTEEL
    OLDSTEEL 1/2 ton status
    Mar 11, 2000
    107
    SANDIEGO CA
    If it did not come originally with smog equipment,you will pass emissions visiual inspection, but the smog test is up to you. If you fail the first time they will give you an extra 30 days to correct, so if your in a rush just go down and fail the first one. It gives you idea where to start making adjustments.
    74 K5
    Leave it like you found it, or better!
  4. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    It also depends on which motor came in that one. Before '78 they did have Cats on Blazers. But in '78 if the Blazer had a 400 in. motor (like mine did) it came from the factory without Caton them and no other smog except a PVC valve. Good luck.
    C'moe
    <font color=black>the blazer is "Back in Black"
  5. Steve88
    Steve88 1/2 ton status
    526
    Sunny Arizona !
  6. OLDSTEEL
    Mar 11, 2000
    107
    SANDIEGO CA
    They still test all years, but they do not look under the hood for 72 and older. Back in those days no one was concerned with air quality.
    74 K5
  7. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Hum, I wonder if they are doing like Calif. taking my money. I have a 1977 Blazer and "they" said it must be tested.
    I think you are worng about the 15 year rule, its like 1967 and newer need the testing in AZ.
    If you can post a web site, why don't you read it ?
  8. Steve88
    526
    Sunny Arizona !
    ...I barely have enough time to read coloradok5.com...
    <font color=red>Steve88</font color=red>[​IMG]
    88K5 Silverado
    thunderdog@metallica.com
