AZ rear 10/12 bolt rear disk conversion
Discussion in 'The Garage' started by bryguy00b, Jan 11, 2004.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    is it worth it? i suppose only if ur planning on keeping ur 10 or 12 bolt. if i wind up keeping my truck im ganna be swapping a 14 under it, they make a disk conversion for that? i know its been done but im not sure who makes kits or w/e
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    az-kickin offroad makes the 14bff rear disc brackets, and they are SWEET..when we did chevy4wd's, neither of us thought that they would be as stout and "pretty" as they were when we saw them.. a great product, and 3/4 ton 4wd front rotors, with 3/4 or 1/2 ton front calipers will complete the swap.. /forums/images/graemlins/thumb.gif
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    hmm how does that work with the hubs that are on the roters and all that?? guess id have ot see a picture of it..
  4. Confedneck
    Nov 1, 2002
    5,236
    bry..
    you seperate the drum from the hub...
    then reinstall the rotor onto the hub...
    all new wheel studs, new races, bearings and seals...
    and make sure everything that came out, goes back in...
    really simple swap, and the bracket for the caliper mounts to existing holes in the axle tube for the drum backing plates, and you can clock the bracket around the axle for clearance.. /forums/images/graemlins/thumb.gif
  5. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    got any pics of it?
  6. Confedneck
    Nov 1, 2002
    5,236
    i dont.. email/pm tonyP or 45acp.. they may..
  7. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    got any pics of it?
    Here is a website with some excellent pics of the 14BFF disk install. /forums/images/graemlins/thumb.gif
  8. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    great! thanx! /forums/images/graemlins/thumb.gif
  9. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
  10. Confedneck
    Nov 1, 2002
    5,236
    cut? no, the rotor is bought new, or machine an old one.. rotor only, the rotor and hub seperate, as do the drum and hub.. you use 3/4 ton rotor because it too, is 8 lug, the same as the hub for the 14bff..
  11. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    so the FF hub bolts to the roter w/ those stands offs that the kit comes with?? thats what it looks like to me..or im seeing this wrong.. /forums/images/graemlins/thinking.gif
  12. Confedneck
    Nov 1, 2002
    5,236
    no....
    the drum comes apart from the 14bff hub
    the rotor takes its place
    the brackets come with aluminum spacers for mounting purposes..
  13. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    well thats basicly what i ment...lol
