B&M floor mounted shift - Which one?
Discussion in 'The Garage' started by 45acp, Sep 10, 2003.
  1. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    I am about to change steering column in my 1980 and want to replace the column mounted shift for the TH350 on the floor. Which B&M shifter has worked best for you? /forums/images/graemlins/confused.gif
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I havent seen one up close but I am going to go with the light truck ratchet shifter. It is the same fast shifter you can find in many pumped musclecars just with a taller base. It is available from summit. There is also shifters from Lokar that are pretty cool.... looks like a standard shifter with a mini piston on top that is optional, they come in different lengths.
    85K5 3/4ton,14boltFF,10bolt,9"lift,35"boggers,16.5x14welds, big horse 406SBC/700R-4 /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif
  3. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I have seen both the light truck shifter and the regular one found in cars in trucks depends on where you want your shifter at might want to look at dimensions of both.....Jason
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I use the B&M light truck megashifter. Have it in two K5's. Looks and works great.
    John
  5. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    I've also got the B&M light truck megashifter. It works great. You can adjust the height to however you like it. Up to the max that is.
  6. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Got with the Art Carr Gate Shifter, it is super sweet and cable operated. You can mount it on the door panel if you wanted to. /forums/images/graemlins/grin.gif
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    I second the Art Carr... /forums/images/graemlins/thumb.gif
  8. earl87gta
    earl87gta 1/2 ton status
    Apr 6, 2003
    551
    Chuckey TN
    Im putting a new column in my truck and changing back to the column [I love Jeeps] for a B&M rachet shifter If I get it done soon I will take a pic of it and If you want it I paid 40 for the new shift linkage for my truck so I will let the rachet shifter go for that if the shipping isnt bad I will pay for the ride. I will pm you when its out of my truck I hope to do it this week but it seems like I never get to do what I want to do any more work just keeps me to busy
    Earl
