B&M Megashifter
Discussion in 'The Garage' started by 77crewcab, Nov 30, 2006.
  1. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Can someone answer a question on these for me. I am trying to figure out if this shifter can be used as a regular detent shifter and a retchet type shifter. B&Ms website doesn't say. On their Star shifter it describes that both functions can be used but doesn't say on the Megashifter description. I want a shifter that can do both but that will work with a 700, 350, or 200r4.
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    It is a ratchting shifter in L1 L2 and D (OD) then it detents in R N and P. It dosent have a full detent option.
  3. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Okay can you just put it in OD or D and go? Not worried so much about the lower gears for daily driving. Basically just want to be able to have PRN(D). I may just go with their sport shifter or unimatic.
  4. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    Correct.
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    As said, correct. It's a good shifter. Only reservation about it is that if you're really getting on it from 1st, ratchet to 2nd etc you can ratchet straight into N which is a bit dumb but a minor complaint.
  6. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Maybe the start shifter would be better then. From the sound of it in ratchet mode only the forward gears can be accessed.
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yeah, there's a posotive lock out for R etc.
