B&M SuperCooler 28000 for 700R4
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BettyBurb, Jul 22, 2003.
  1. BettyBurb
    BettyBurb Registered Member
    Dec 14, 2002
    52
    NorthEast Colorado
    I am putting a B&M SuperCooler 28000 GVW in line with the trans cooler in the radiator. I am mounting the SuperCooler with the fittings facing to the passenger side. Should I connect the line coming from the top fitting on the radiator to the bottom or the top fitting on the cooler ?
  2. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yes the top line on the radiater should go to the cooler...with a rubber hose provided..and then another hose coming from the other side of the cooler..back to the cooler line on the radiater... i just put a 24,000 super cooler in a week ago /forums/images/graemlins/grin.gif
  3. BettyBurb
    Dec 14, 2002
    52
    NorthEast Colorado
    OK,
    now I am still wondering if the line going into the cooler should be at the bottom or the top. In other words should the fluid flow up from the bottom of the cooler to the top and then out to the transmission or flow from the top to the bottom and then out to the tranny ???
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I run it in at the bottom and out at the top. That's the way the cooler inside the radiator is plumbed, so I just do the same with the external cooler. /forums/images/graemlins/cool.gif
  5. BettyBurb
    Dec 14, 2002
    52
    NorthEast Colorado
    That makes sense, to do it the same as the cooler in the radiator.
  6. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    The top line on the radiator is the return line from the cooler. The fluid flows up the radiator cooler. This keeps the fluid in contact with the cooler longer as it is pushed to the top. The external cooler should get the fluid last as air cooling is not as good as the fluid cooling. Feed in the bottom, out the top, unless its a cross-flow type.
