B/S on rim for d60
Discussion in 'The Garage' started by JUNIOR-K5, Jan 26, 2006.
  1. JUNIOR-K5
    JUNIOR-K5 1/2 ton status
    Dec 20, 2005
    387
    SO.CAL
    What would be the ideal backspacing for a d60 and 14ff combo.
  2. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    Something between 2.75" and 4.25". From what I understand too little or to much can cause bearing-wear issues. I have run both 4.25" and 3.5" BS wheels on my D60/ff14b with no issues.
    j
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    What J said except if you are running 15" wheels you will need to grind the calipers for more than 2.75 BS and you probably can't go more than 3.75.
    I am currently running 4.25 on 16" wheels, 15s on the way with 3.5 - I will be grinding :D
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I am running 15s with 4.25 backspacing and they fit fine. However I did spend 3-4 hours grinding the **** out of the calipers:D.
    Ira
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Holy ****, big job! You feel that there is still plenty of material on the caliper? Do you trust it for DD duties?
  6. sandawgk5
    Oct 28, 2003
    6,881
    Ya plenty of material. These calipers are ****in huge. I would say that even with all of the material I have ground off they are still thicker than 10 bolt calipers 1/2 or 3/4 ton. The thinnest portion which is around the edge of the "window" on the caliper is about 3/8 of an inch with the caliper increasing in thickness as you go out each direction from the window.
    Ira
