Bach to a stock cooling fan
Discussion in 'The Garage' started by opfor2, May 18, 2003.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Years ago, I was told that by changing the stock fan to a “Flex Fan” would provide better cooling. So I did change my stock fan to a Flex-Fan and now I want to change it back to a stock configuration. Here is the problem, I’ve moved a few times and I’ve lost the stock fan, clutch and bolts. I would like to know what aftermarket set up can I use ? I spend a lot of time in the hot desert and I need the best stock cooling set up.
    thanks
    Dan..
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Look for a 70s 350 in a junkyard. My motor I rebuilt came with a 7 blade clutch fan. I run that one right now and it cools pretty darn good.
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    So that's the theme for today eh????
    I found mine today was bent, I'm gonna start junkyard shopping for an electric within a couple of weeks.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Don't get a fan from a 70's truck. It will blow air forward in your truck. /forums/images/graemlins/eek.gif Your '90 should have a serpentine belt drive, which drives the water pump (and fan) backwards from earlier engines. So you will need to find a fan and clutch that came from a truck with the serpentine drive.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    oh you are very right, sorry I didn't notice the 1990. DON'T USE a 70s fan like he said. Just junkyard for a factory serpentine chevy TBI truck fan.
