Back-firing through the carb, suggestions?
Discussion in 'The Garage' started by Okiemuddog, Jun 13, 2003.
  1. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Well, I got my pipes on my blazer and rebuilt my carb. I have got all my vac lines hooked up, but it is backfiring through the carb when you accelerate it hard, if you inch the throttle open then it does not do it. I am open to any suggestion as to where to start looking for the problem. I am still in the erly stages of getting this engine running correct, but would like to fix this problem fixed first.
    Oh, BTW I am running a stock 4bbl Q-jet from a '74 burb on a stock intake.
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Check the timing with a light, vacuum disconnected and plugged at the distributor, sound's a little advanced by the way You described it. /forums/images/graemlins/eek.gif
  3. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Rule of thumb:
    Poping through the carb - it's lean, the engine is "looking" for more fuel to burn.
    Popoing through the exhaust - it's rich, the engine is still burning the fuel it has.
    Remember, a lean mix burns very-hot and quick. A rich Mixs burns slow and cool.
    Based on the above comments.
    What do you think it could be ?
  4. Klink K5
    Klink K5 1/2 ton status
    Aug 3, 2002
    549
    Northwest Iowa
    Timing could be way off or you might have a flat lobe on the camshaft on the exhaust side. My .02 cents.
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    About six months ago I had a problem with back firing from the carb. After much head scratching and parts purchasing- This is what the problem ended up being-
    This is the #6 exhaust lobe on the cam-
    This is the lifter that was on top of that lobe-
    My truck has been parked since and my big block is on the stand in the garage. /forums/images/graemlins/frown.gif
  6. XtrmChevy
    XtrmChevy 1/2 ton status
    Jul 14, 2001
    148
    Finland, Europe
    Check your spark wires, once I put them back wrong and the symptoms were similar... /forums/images/graemlins/tongue.gif
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    my K5 is backfiring throught he carb on acceleration to mine is becuase its running really lean and the accelerator pump isn't working right(its leaking actually) so its starved on acceleration.
  8. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    could be timing but id have to say since you rebuilt the carb and it started doing it, fuel is the problem. my q-jet did the same exact thing. would pop unless i eased into. my solution...Holley!!! its perfect now.
