back firing through the carb
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Jun 5, 2001.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    OK, i just got my vortec heads on and it starts up and it will idle just fine but when i give it gas it hesitates and backfires through the carb. What could cause this, maybe the intake valves arent closing all the way? could it be the carb is too lean? any help would be much appreciated.
    Check out my 73 K5 http://members.theglobe.com/xnoahx/73k5.htm
  2. ericsoffroad
    ericsoffroad Registered Member
    May 29, 2001
    27
    wa vancouver
    i would run a compression check to see if your valvs are closing all the way if the valvs are doing there job check timing the timing may be to far advanced
    just my 2 cents
    are we having fun yet
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Check at least two more times to make sure that you don't have two spark plug wires crossed. A V-8 will idle surprisingly well on 6 cylinders.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  4. Grim-Reaper
    7,385
    Atlanta
    Did you do any work on the cam i.e. replace it or the chain? When you install a cam the 2 dots facing...this is not TDC. If the dots were not pointing up on both cam and crank you installed the distributor 180deg out. Pull up on the distributor but don't turn it tun the crank one full turn and drop the distributor back in.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  5. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    70 psi is way too low. 150 is more like what I'd expect to see, depending on your altitude. It drops slightly as altitude increases.
  7. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
  8. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Try adjusting the valves they are probably to tight, if you are getting 70psi. You could be running a little lean, does your exhaust have a funny smell now? Remember your flowing a little more air now, so will need to flow a little more gas.
    1978 K5, Palisades Park, NJ 07650
  9. Storm Trooper
    Nov 24, 2000
    4,640
    1st, did you find anything?
    2nd, lets start all over, what motor are you running?
    You said you put new heads on, did you change manifold, dist., carb., rockers, lifters, push rods, cam etc.? Did you turn the crank at all while apart? Did you put the distributer back in the same direction if not? Proper imformation from you will make it much easier to help you out.
    [​IMG]<font color=red>[/b]"Rid'in HigH in my K5"[​IMG]
    ....[​IMG]<font color=blue>[/b]"6" Lift -<font color=purple>38.5's"[​IMG]....
  10. Blazer1970
    1,600
    Old Mission, MI
    I get 180 - 190 psi compression with my motor with Vortec heads and stock type dished pistons.
    Tim
    87 Burb 4X4 350
  11. Grim-Reaper
    7,385
    Atlanta
    70! wooooo thats big time low. Uhhhhhhhhhhhhhhh back to my question...did you mess with the cam? Now it's sounding the the cam is not indexed or the valves are not closing or you wasted a bunch of time with a motor with bad rings but even bad rings should pull over 100.
    Grim-Reaper
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Here's another thought, did you adjust the rockers properly? If the adjusting nuts are too tight then the valves won't close quite all the way.
  13. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    its a 350 i did a cam change a while back and it has ran fine so thats not the problem, when i did the heads, i also switched to a edelbrock performer for the vortec heads and put in an HEI. The distributor is in right because i know what cylinder its on when i adjust the valves. Im going to try loosening all the valves a bit. It mights just be my compression tester is bad, ill try to get another reading pretty soon today, im just letting the engine cool a little before i touch it. im also going to play with my vacuum advance a little, its an adjustable unit on the distributor so maybe its set too far advanced.
  14. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    Ok, the tester is junk, its letting some of the pressure escape through the release valve so i have more than 75 psi per cylinder i still need to try the valves
  15. dyeager535
    26,979
    Well if everything is setup correctly, vacuum advance won't have any effect (ok realistically there is a bit of "leakage" so there might be a tiny bit of advance) on idle. Should be run on "ported" vacuum only, no vacuum to advance cannister at idle.
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
  16. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Had this happen on an old Buick I had. Check to make sure the EGR is working correctly. For some reason it started puking flames at me when the EGR crapped out. Wierd eh?
    Why do people keep calling it a Bronco!!!!! [​IMG]
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just lose the EGR completely.
    I'm suspecting valvetrain. Could also be timing or carb related, but I say valvetrain first.
    Tim
  18. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
