back glass
Discussion in 'Audio' started by 85GMCJimmy, Sep 13, 2001.
  1. 85GMCJimmy
    85GMCJimmy Registered Member
    Feb 21, 2000
    83
    South Carolina
    Does anyone elses rear glass rattle ridicualously loud? Mine when my stereo is hitting, it rattles so much, it stereo itself sounds good inside the truck, but the rear glass vibrating is a little bad, but it really turns some heads b/c of that loud racket the glass makes. lol Do anyone have ideas about minimizing it or elminating it? Would a new seal help?
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    A new seal would help. Mine use to rattle the back window, and door windows. It pushed the side glass out almost a 1/2 inch when it hit. I just left the windows down, and it was fine. For the back either leave it all the way up or all the way down. ( the "use to" is because I rolled my Jimmy:( No top anymore, or doors.)
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I had that problem when I used to have a big system. After you replace the seal, run some 1/4" closed cell foam "rope" weatherstripping inside it - it will knock down all of the rattling.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  4. MITCH_89'
    MITCH_89' Registered Member
    Dec 7, 2000
    91
    GULF BREEZE, FL.
    mine rattles with the window all the way rolled up. I bump my window switch to where the rear glass just barely goes down, and no more rattle!!
    BLAZE IT UP!!
