Back power window wiring
Discussion in 'The Garage' started by Lotsa_Faith, Jan 12, 2006.
  1. Lotsa_Faith
    Lotsa_Faith 1/2 ton status
    Jul 10, 2001
    474
    Mckinney, Texas
    theres two wires coming off the motor on the back window. I got a momentary switch that has 3 prongs on it, two on each side then one in the middle. Any idea what wires go where?
  2. goldwing2000
    goldwing2000 Guest
    The switch wires are one power in and two power outs.
    The two wires going to the motor are both power wires and it grounds to the motor body.
    Just match up the colors and make sure you have a good ground.
  3. Lotsa_Faith
    Jul 10, 2001
    474
    Mckinney, Texas
    so would i be able to test it without mounting the motor in the tailgate how its supposed to be? I tested it with the wires from the motor on the two outer prongs, and the power from batter in the middle earlier and it didnt work...
  4. Tux
    Tux Registered Member
    Jan 9, 2006
    14
    Phx
    You are going to want to ground the body of the motor either by holding it directly to the neg term on bat or (perferred) running a wire from neg term to the body. Then take a wire from the pos term and touch to the posts on the electrical connector on the motor. One should cause the motor to turn clockwise and the other counter clockwise.
    Pj
  5. tsquared275
    tsquared275 Registered Member
    Jun 28, 2005
    13
    Plano, Texas
    Bad Squeak
    Does anyone have this really bad squaking sound when the window is being rolled down and it is near to being all the way down? Its a power window, and it sounds like its coming from the window itself, not the motor or nything. Thanks!
  6. goldwing2000
    goldwing2000 Guest
    You might want to start a new thread instead of thread-jacking one about a different subject.
    You'll probably get more replies.
