back pressure
Discussion in '1982-Present GM Diesel' started by biltntboght, Feb 22, 2002.
  1. biltntboght
    biltntboght Registered Member
    Jan 9, 2002
    37
    Medina,Ohio
    I am putting a new exhaust system on my 6.2 blazer and wondered if I can use mufflers from a farm tractor. I was told that I had to have back preesure or I would warp the valves. I thought only a gas engine needed back pressure. I know my tractor basically has a straight pipe muffler and I thought my Blazer would sound awesome with tractor pipes. So ...is it true about back pressure or would any muffler do??
    Todd
    As you travel on thru life whatever be your goal keep you eye upon the donut not upon the hole
  2. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    You don't need back pressure. I've never heard of anyone warping the valves for any reason, let alone because they didn't have enough back pressure. I would only be concerned about creating too much back pressure, so make sure the pipe diameter is big enough, say at least 2" if your running duals and at least 3" for a single pipe.
  3. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    I've heard it was possible to warp a valve if your exhaust system is too short. Cool air could get to the hot valve after you turn the engine off and make it unhappy. I would only worry about this if I was running open manifolds or no manifolds at all.
    <font color=red>When in doubt, empty the magazine. </font color=red>
    <a target="_blank" href=http://www.geocities.com/calcide>http://www.geocities.com/calcide</a>
    1983 K5 Blazer Silverado, 6.2L Diesel
