back pressure
Discussion in 'The Garage' started by jacked_86chevyk10, Feb 23, 2004.
  1. jacked_86chevyk10
    jacked_86chevyk10 Registered Member
    Feb 4, 2004
    42
    SNELLVILLE, GA
    how much back pressure do u need- i have a sbc 350 -i want to cut my exhaust off b4 my flowmasters (bc theyre old and sounds BAD) so how much pipe do i need to leave on-
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    you want to run with open exhaust...no mufflers??
  3. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    295
    Truckee, CA
    If what i remember is correct, you will need more than just a certain legnth of tubing to achieve the correct backpressure. Most ppl achieve this with mufflers and/or cats.
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Nascar/Stock cars run mufflers?, top fuel drag cars run mufflers? don't worry about back pressure, run with out the mufflers if you want noise. Running long enough pipes out the back will quiet the tone just a bit anyways.
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Do you crawl at 9000+ RPM all day? You need some backpressure to help make torque on the low end.
  6. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Thats the job of the gears, whatever though, everybody has their own opinions i guess, finding this out with this web site, weird ones at that. I'm out. have fun.
