Back spacing on Hummer rims?
Discussion in 'The Garage' started by TONYP, Oct 7, 2003.
  1. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    after seeing all the problems guys are having with the hummer rim centers, I'm going to use DRW hubs up front and on the rear I'm going to machine the 14ff hub and slide an alum hub over it. The alum hub sleeve will bolt to the 14ff with the stock lugs, then the rims will bolt to the alum hug sleeve...the alum hub sleeve will be a press on fit to the 14ff hub....so i need to order the alum today and just need the back spacing on the hummer rim...thanks /forums/images/graemlins/thumb.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/thumb.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Stock BS is 7", rim width is 8.25. /forums/images/graemlins/thumb.gif
  3. TONYP
    Aug 13, 2002
    2,116
    so cal
    that works, I'll order 3.500" thick round stock and have a go at it... /forums/images/graemlins/thumb.gif
  4. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    I have a set of the newer 12 bolt style hummer rims and the backspacing is just over 7". Approx 7.25". I am running a DRW Dana 60 front axle and a Van 14 BFF with 2.5" spacers in the rear.
  5. TONYP
    Aug 13, 2002
    2,116
    so cal
    was just thinking I need 1"inch extra on the rear per side, and what is the lenght of the nose on the 14ff hub, from the rim pad to the outside...I have all the parts at home so I could just check tonight, but if someone knows then I can get the alum ordered today... /forums/images/graemlins/thumb.gif
  6. K5BLT4FUN
    Feb 28, 2000
    496
    Peculiar, MO USA
    A SRW 14 BFF hub is 1.75" and the axle flange is 0.1875"(3/16). A DRW 14BFF hub is different. Don't know the measurements on it.
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Layne, got any pics of the rims mounted to the hubs? I'm interested in seeing how far the hubs protrude past the wheel, if it does. I know the front DRW D60 won't stick out but how does the rear hub look?
  8. K5BLT4FUN
    Feb 28, 2000
    496
    Peculiar, MO USA
    I am on the road this week, but once I get home I will take some close up pics of the rims installed on the aluminium adapter, the adapters them selves and with the rims just on the axel.
  9. TONYP
    Aug 13, 2002
    2,116
    so cal
    so a DRW 14bolt hub you think has the rim flange out farther then the SRW 14bolt hub..
  10. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    No, a DRW 14 bolt has the rim flange deeper on the hub than a SRW version. A trick for adding track width is using SRW hubs on a DRW axle.
