back spacing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chris77k5, Nov 29, 2001.
  1. chris77k5
    chris77k5 Registered Member
    Nov 26, 2001
    19
    washington,puyallup
    I going to buy new rims to put 35s on a 15x10, i want to know what back spacing will i need i don't want them to stick out to far
    77 k5 400sb, edelbrock rpm, carter 625,4" rancho 3" body, 3.08 10bolt 12bolt 33-12.5 soon to be 4.56 and 35s bfg km
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    4 - 4.25"
    I am running 35s on 16 x 10 with 4.25 inch - perfect.
    Check out the pics in my signature/link.
    Dave
    Horn Broken... Watch For Finger.
    <a target="_blank" href=http://coloradok5.com/gallery/Daves-Pics>http://coloradok5.com/gallery/Daves-Pics</a>
  3. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    Stock on a 10B 6 lug is 3 5/8.....if you go 4", you will Probably have a clearance problem with a tie rod end......this is for a 15" like you asked.......Not a 16" or an 8 lug.....a couple guys say that they have no probs with 4".....Most say it hits the tie rod end....Mine hits the tierod with 4", so I use a 3/8 spacer when I run my 10"......I'd say trial fit 'em on the front first.......
    Stuck?...Hell no..I still got some gas left..
  4. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Good call K5Jimmy!
    Dave
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    K5Jimmy,
    I just read your profile - we share a common taste in vehicles. I think it is a great combination!
    Dave
  6. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I run 15x10 8 lug steel with 4 1/8" backspacing and they dont hit the tie rods. I think my old 6 lug wheels were the same, they didnt hit either
  7. chris77k5
    Nov 26, 2001
    19
    washington,puyallup
    hey thanks for the help guys
  8. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    The 8 lug front ends are two inces wider than a 1/2 ton, which means the wheel mounts an inch farther from the tie rod, my old 6 lug 15x10s were 3-5/8 backspace the new 16x10s are 4.5 almost the exact same width as before. take off a wheel put a straightedge across the mounting pad on the rotor and measure back to the tie rod to find out how much room you have.
    Leland aka RaisedK5
    "Of all the things I've lost, I think I miss my mind the most!"
    "Are the voices in my head bothering you?
