Back to a stock cooling fan !!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by opfor2, May 18, 2003.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Years ago, I was told that by changing the stock fan to a “Flex Fan” would provide better cooling. So I did change my stock fan to a Flex-Fan and now I want to change it back to a stock configuration. Here is the problem, I’ve moved a few times and I’ve lost the stock fan, clutch and bolts. I would like to know what aftermarket set up can I use ? I spend a lot of time in the hot desert and I need the best stock cooling set up.
    thanks
    Dan...
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    please don't post the same topic in multiple forums its a little pointless.
  3. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    come on someone should be able to help me on this..
  4. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    someone responded to another post(same question). I saw it a couple of days ago.....check there for help
  5. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    hey, ive got a stock fan from an 85 silverado, im in ventura, if you want it, you can come by and pick it up for $25
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    why are you switching back? I never heard of anyone having a complaint with a flex fan. I mean my 7 blade fan works great but the clutch is broken so its always spinning no matter what.
  7. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I've got a complaint or two on flex fans.........
    What are they good for? Bling bling factor and that's it.
    Didn't increase cooling. Made the truck sound like a bad a** when the rpms were wound up.
    And one more thing, don't hit deep water in them /forums/images/graemlins/thumb.gif
