Back to the high altitude jetting?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by WheelinK5, Oct 20, 2001.
  1. WheelinK5
    WheelinK5 Registered Member
    Oct 12, 2001
    55
    Vegas
    I am running way too rich at idle and cruising but if I stomp on it, it is perfect.
    Edelbrock is sending me .070 jets and metering rods to go with it. My carb comes stock with .069 jets. Why is Edelbrock going up in jet size?
    Anyone here with a Edelbrock Q-jet? Can you tell me the correct jets and rods to use here at 5200 ft.?
    Mark
    1985 K5
    Built 330HP crate 350, SM465, NP208, 10 bolts, Ranchos and 31X10.5 on Rallys!
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Well if you're way too rich at idle, that's an adjustment problem.
    If you're too rich at cruise, you need to go smaller on jets unless you make a drastic metering rod change.
    Tim
