Back window lock
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76 jimmy Az, Apr 27, 2000.
  1. 76 jimmy Az
    76 jimmy Az Registered Member
    Mar 14, 2000
    35
    Tempe, Az
    Hey i have a manual back door handle and the key lock is broken on it, i dont have any idea why it just stopped working. i really would like it get it working again but i cant find a new lock in LMC, only a power one. Anyone get this problem? is there a way i can fix it
  2. BB454
    BB454 1/2 ton status
    Apr 2, 2000
    134
    Gauteng South Africa
    The lock is of the most basic of locks found on all door and trunk applications for vehicles. I,m sure if you remove the lock you will see that repairing it is a simple procedure and if it is badly busted then replacing it is even easier. I have repaired mine with parts found at a junkyard in under 30 min. Have a go at it - there is no great tech. obsticles. Just be carefull with that rear glass, and have fun.
    BB454
    IF IT DOES NOT HAVE 8 PISTONS - IT'S BROKEN !
  3. 76JimmyinAZ
    76JimmyinAZ Registered Member
    Mar 31, 2000
    6
    Mesa, Arizona
    Okay- this is weird. Check out my username- AND my manual back window lock doesn't work EITHER.
    Strange coincidence??
    Tony J.
    Mesa
    ILUVMYTRUK
  4. Todd78/87
    Todd78/87 1/2 ton status
    Feb 18, 2000
    436
    Haines, Ak
    LMC 2000 Winter Edition pg 40 part # 36-0704 $49.95 I have put two complete units in my blazers,, both were bough without any window crank at all. It's pretty easy,, dig into it. I took both locks to the Chevy dealer and they matched my door key to the back window key.
    Todd 78/87[​IMG]
    Alaska Bound
  5. buttman
    buttman Registered Member
    Apr 7, 2000
    72
    California
    Mine is broken also. It's kind of sketchy too, all you have to do is stick the key in a bit a turn and the window goes down. Has any body replaced the lock for a power back window? Did you get it from the Chevy dealership? And how much did it cost? Thankyou Buttman
