Backfire after 4.10's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76_Cheyenne, Sep 1, 2002.
  1. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    Backfire after 4.10\'s
    I just got my new 4.10s in my K10 with 35"s. when I let off the gas fast, or when going down a hill and let off the gas I get some backfiring and poping. Is this because the engine now has a lot more compression rolling down the hill's and is normal or does this mean that my timing is off? Thanks
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    Re: Backfire after 4.10\'s
    it's probably more noticable now that the engine is turning at a higher rpm, it is probably due to the timing setting. Resetting the timing should quiet it down.
  3. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    You also might lean out the carb mixture just a little as well as check the timing.
    Bill
  4. 83PJW
    83PJW 1/2 ton status
    Aug 18, 2002
    160
    leavenworth, ks
    also vacum leaks check it out.
  5. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Maybe its time to pack the muffler bearings /forums/images/icons/smirk.gif
  6. 76_Cheyenne
    Jan 23, 2002
    285
    Missoula, Montana
    haha... i bet if I had mufflers instead of glasspacks it wouldn't be as bad.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Well thats where the popping comes from then.
  8. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    More often then not it will be an exhaust leak..Like mine was/is he he...mike /forums/images/icons/smile.gif
  9. 76_Cheyenne
    Jan 23, 2002
    285
    Missoula, Montana
    But if it was an exhaust leak wouldn't it be poping/backfiring all the time, this only occurs when the compression is built up in the cylinders and the revs are up.
  10. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    I was told by a member on here that I know,That it would be an exhaust leak like a crack in the manifold??? - (here is my situation,I have it in 2nd and floor it or get the rpm's up and let off the gas like,like coming to a stop and I get the popping through the pipes..) if it is different I too would like to find out why...Not meaning to hi-jack the post....mike /forums/images/icons/smile.gif /forums/images/icons/smile.gif /forums/images/icons/smile.gif
  11. 76_Cheyenne
    Jan 23, 2002
    285
    Missoula, Montana
    I put new headers and straight exhaust on a few months ago, and I checked and didnt see any leaks? It sorta sounds like a harley coming to a stop, all rumbly with an occasional backfire.
  12. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Your using more compression braking, than before. If you have an adjustible vac. advance. You need to adjust it. Otherwise you just need to adjust your air/fuel mixture and timing. Or upshift and use the brakes. /forums/images/icons/grin.gif /forums/images/icons/tongue.gif
  13. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    It's probably because the engine isnt running just right. If its not firing like it's supposed to it wont burn all the fuel and when that fuel hits the hot exhaust it ignites and backfires. My K30 did this for a while but it stopped after I replaced the plugs, wires, cap and rotor. It still does it ocassionally but not very often.
    Only reason I can think of for an exhaust leak to have an effect is if it's letting more oxygen in to let it ignite.
