BackFire
Discussion in 'The Garage' started by Big Silly, Feb 12, 2006.
  1. Big Silly
    Big Silly Registered Member
    Nov 8, 2005
    7
    Henderson, KY
    I am having trouble with my 350 backfiring while I am traveling at a constant speed in high gear. What would cause this to happen. I have never had this trouble before.
    I believe it to be a small ignition problem, wires, plugs, etc... However, I recently had to have the heads machined on my '88 Blazer. Would this in any way cause this problem or I'm I only paranoid. :confused:
  2. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    timing? are we talking exhaust or carb backfiring?
    thanks,
    James
  3. 13lazer
    13lazer 1/2 ton status
    Dec 30, 2004
    115
    San Pedro, CA
    smog air pump malfunction? i had a 3" hole in my passenger side exhaust manifold that i couldnt see under the heat shield. i swapped the donut 3 times before i saw the hole. with too much oxygen, and unburned gas you can get backfires. the 85 sub with the hole also spit my mufflers wide open a few times thanks to the diverter valve and that retarded heat riser butterfly valve.
  4. Big Silly
    Nov 8, 2005
    7
    Henderson, KY
    Exhaust Backfire
  5. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    what kinda exhaust system do you have?
    thanks,
    James
  6. Big Silly
    Nov 8, 2005
    7
    Henderson, KY
    True duals with flowmasters
  7. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    does it only backfire when you let off the gas?
    PS: are we talking about a mild popping/ gurgling, or one of those crap your pants gernades going off under your truck?
  8. Big Silly
    Nov 8, 2005
    7
    Henderson, KY
    It is only backfiring when the motor is running in over drive at a lower RPM. This happens while maintaining a constant pressue on the acclerator. It's only a moderate back fire.
  9. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    Ah yes, the quality GM exhaust manifolds and those heat shields ... grrr :mad:
    I knew it was bad when the JUNKYARDS sold NEW aftermarket pieces.
    -- A
  10. dremu
    Feb 27, 2000
    15,967
    459
    <hijack>
    What causes this? My bigblock pops and sputters when I let off the gas ... timing, or weird back pressure?
    </hijack>
    -- A
  11. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    well, I'm am VERY VERY far from an expert, but my old green truck did it with straight headers. My straight piped burb does it some when I let off the gas. I think it is supposedly something to do with cold air getting sucked in from the exhaust pulses and detonating left over gas or something.. I've heard that cold air can acutally suck in a chip a valve. But I'm not really certain.. :crazy:
    thanks,
    James
  12. wildmouse216
    wildmouse216 1/2 ton status
    Dec 26, 2005
    135
    Rifle, Colorado
    if you are running too rich or your timing is off it can pump gas out of the cylinders and the excess gas can detonate in the exhaust system and cause mild explosions.
